Oil Pump Adjust
MICHAELSF150
NEWFOUNDLAND
I am adjusting my oil pump I have the two lines lined up at full throttle. I have also read that there is a gap from the cable and the adjuster that i should measuse, I cant find a gap on the cable. I have a 1998 600 twin is there a gap on my cable or is it just the tripple ?
No nothing else to measure,on your sled you just line up the marks at WOT
and your done..
did you do idle and throttle end play adjustments first??
Do these checks in this order;
1st- set idle to 16- 1,650 rpm's(@ operating temp)
2nd- set throttle end play to 2mm adjustment for that is down at the carb rack(holding the throttle pivot point out when measuring)..
