SRX7
I have one sitting around from my SX.Will it help or hinder back shifting and over all aggressive trail riding.
sure will but what weights and springs you going to run with it??
yamaholic22
Hey Tom,
On my '01 SXR 700, do i have to change the stock 16mm rollers to 14.5mm rollers if i do anything to the clutches? I know for sure they don't work very well with 8CA's, wondering how they would work with like 8DN style weights? Let me know if you know anything about it.
I run the 8ab weights in my sxr with 14.5 mm rollers.... I know the 8 ca weights work much better with the 14.5 mm rollers and I never cared for the stock weights.
monker
the info I have all points to 14.5 rollers. That's what I'll be using for clutching this fall.
On a 01 sx-r the 16mm rollers will work if you run a 51/43 with the 8df weights with 4.5 gram rivets in both holes. Good trail set up that will backshift pretty good!
SRX7
everything is stock on my SRX
51/43 should work fine with 89a-10 or 8bu-10s, What do you think Turk???
51/43 will work well with 8bu-10,s. 51/43 will work with 8bu-oo for racing only....load the tip & about 2.4 in mid. Don,t go in deep snow, you will get stuck!
SRX7
what weights are in there now? and what should I wrap the secondary at with the 51/43?Turk said:51/43 will work well with 8bu-10,s. 51/43 will work with 8bu-oo for racing only....load the tip & about 2.4 in mid. Don,t go in deep snow, you will get stuck!
Thanks guys
You have 8dn-20 weights. These weights work really well on the SRX when running at proper rpm,s(83-8500 rpm) You can add the helix, run 4.5 gram rivets in both holes. Right now you should have a 3.6 inner & a 4.5 outer. Wrap secondary at 80 with the stock red spring. You might want to run a Yammie w-w-w primary spring.
SRX7
Thanks Turk,I guess I'll wait for some snow cause the only time I tested the sled was late last year and I took note (the sled head I am) of the rev's and it seem to me that they were at 8500ish but not really sure.I bought the sled just a month ago and therefore looking to set it up.
When I set my old sx700 with your specs and tripple pipes ( it ran like crazy )the sled did not like the 51/43 helix, it seemed to pull better in the mid to higher rpm with the stock helix.
Thats why I have this helix left over.
