figured i'd post some pics of my exciter project, i've had tons of tech questions answered for me on this site so here are a few pictures of her. it sat in the previous owner's back field for 4 years and took a little restoring to get it going including replacing all fuel and oil lines, filter and rebuilding the pump. but I didnt stop there. what started as a simple "just going to get it running" turned into almost the full winter of changing this and that to my liking. i finally got to take it out on the trails this past weekend when we trailered up to Hurley WI for its maiden (and last) ride this winter. Will definatly be widening the front end this summer, and i might be changing the rear skid again, i majorly ate slides due to the xtra 12's natural bad approach angle and the combination of that and the smaller 8 tooth drivers. track tension was correct. anyways on with the current mods and pics.
body:
polished tunnel
yamaha blue front clip
aluminum handlebars with 3" riser
PowerMadd throttle extension
shortened windsheild
drivetrain:
primary: 52gram weights, comet blue spring
secondary: stock 45 degree helix, SX pink spring
SX 38mm flatslide carbs. stock SX jetting
SX y-pipe
PSI single pipe
Bender Racing cold air intake
Bender Racing torque arm
stock 17/31 gearing
Wahl Bros Racing 8-tooth no slip drivers
Camoplast 1" ice ripper track 240 carbide tips
suspension:
96 Polaris Xtra-12 rear with fox shocks 13.1 inches of true rear travel
graphite slides
GYT adjustable front struts 2" longer travel in front
(96 V-max XT struts with GYT shocks installed)
composite ski's from 2006 Yamaha Attak
body:
polished tunnel
drivetrain:
SX y-pipe
PSI single pipe
stock 17/31 gearing
suspension:
graphite slides
