(Overrev at top end).
Soo.. when you can't add more weight to the tip of the weights you have to go up in helix end angle?
You need a helix with a steeper finish angle
all helix,s are not cut the same so you won,t allways get the same result
a steeper finish can/will change initial rpm,s slightly also.
RJH
If you acquired over-rev at the top – you may be over revving the entire range. That is - the shift curve is above the power band.
The free way to check this – is simply soften the secondary spring twist – do that test then go angle changes if necessary.
