Parts Help Please
Blkhwkbob
Des Plaines, Il.
02 Viper. On the carbs is a white 90 degree plastic elbow that the plastic tubes connect to then run up to the airbox. The parts diagrams don't show a number for the elbow. I broke one today. Do they just thread into the carb or is there more to it than that?
Thanks in advance.
no they're pressed in, I have them if you can't get one, did you break off the plastic end and the brass piece is still in the carb? rotate it back and forth it will come loose.
