rx1jim
I am in the process of rebuilding the stock rear suspension on my 03 RX-1 and then my SRX is next. I have eliminated all of the lousy plastic bushings with oil-lite bushings that I machined. All of the aluminum shafts which ride on the bushings have been modified with stainless steel sleeves where the shaft contacts the bushings. No more worn out shafts and bushings after only one season. My question is are some or all of the shafts and bushings in a 2000 SRX the same as the 03 RX-1. If there are any that are the same, I'll just make them now while I am setup (and before all the summer chores start). I figured I'd ask since I don't want to have more than one sled torn apart at a time, no room. thanks!!!!
rlbock
suspensions
both suspensions are the same, srx has shorter shocks.
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
SRX also has a wider upper rear cross shaft.
rx1jim
Thanks!! I'll keep making more oil-lite bushings.
