SRX 600 Clutching Help
ss racing
Northern Minnesota & Mancelona Michigan
I have a 98 SRX 600, its all stock except for a 1 1/4 ripsaw and long travel rear suspension and front shock drop down brackets. I just trail ride with my wife and her 2000 SXR 600 and what I need is clutch help. I don't care about the top end I just want it to scream out of the hole, I know nothing about clutches so what do I need to buy. Any help I would be thankful for.
probably get some heel clickers, a multi-angled helix (unsure of angle), and green secondary spring. maybe even drop a tooth on the top sprocket. contact either "turk" or "800" on here, as either of them are very knowledgable on this subject.
stock primary spring
8bu-00 weights with 2.4 grams tip & inner hole empty
45/39 helix with a silver secondary spring at 60 wrap.
Hang on.
I've got that set up sitting on the shelf. $140 shipped to you. I ran it in my 600 with great results. The only reason I switched was that my 600 got bigger last winter :-)
i said green spring, i meant silver. i was thinking of the 700 srx. turk, would it matter which brand helix? cause i know you said that some brands are more aggressive shifting than others.
