who is the best electrical men out here i got a good question for him :-))
taylzee
Ask the question and you may or may not get an answer!
well i wanna know witch wired to take to feed the cluster of a viper in a srx body... they have a fused on viper and don't have in a srx but both wired goes to load control relay can i run a wired from there put a fused and run it to the cluster
srxspec or betheviper would be my suggestions. they have both done what you are trying to do. Maxdlx
thnx max great to know i'm not the first one to do that ...
Having a strong electronics background I could answer, but would simply be reading the schematic to do so. I do not have the wiring or logic schematics for inside the CDI itself. I will wait to see what others who may have this info or actual testing results have to say.
Can you elaborate on what you are trying to accomplish?
just try to find where to take power to feed the cluster ..cluster is for a viper but in a srx sled ... well they have all the wiring in the shop manuel on the site but just wanna make sure ....i just need a second advise
all other signal seem to come from ground from different item ..tach,gaz guage ect
