Does anyone have a 6 ft by 12 ft enclosed cargo trailer that they haul there sleds in? I have 2 97 vmaxs and I found this size trailer for a good price.. I think it would be tight, but I think it would work!!!!
thaks hambone
thaks hambone
orlo
Hambone, Check out your local Craigs lists. There are so many sled trailers here in michigan for sale, "cheap too!!" , that would work way better for you. I see them on a daily basis. Good luck!!
i have looked. I need a cargo more than I need a triton 2 place enclosed, because I can use the cargo trailer for my buisness as well. I think it would be tight for what I want but I think it will work. LOL . Orlo if you find one willl you let me know thanks alot my friend!!!!
Hamrizzle
Hamrizzle
Set the sleds together in the garage nose-to-tail as tight as you can get them, and measure. If you have the exact measurements of the inside of the trailer, simply drawn out a rectangle on the floor with tape.
To get down to 6 feet it is going to be tough even if you offset them as much as you can for the 12 feet. Getting them in the trailer is going to be a pain even if you have reverse. Most cargo trailers do not have a front door, so you will have to drive one on, then back (or wrestle) the other one on. Then you will have to drive one off, and then back (or wrestle) the other one off.
Watch out for door width, that can complicate matters a bit.
