ATACC on my MM?
yamaha_nisse
Sweden
Hi,
Havin' thoughts about instaling ATACC on my Mountain Max 700 '01.
I've installed Bender tripple pipes, and changed domes'.
Having plans to put Booost bottle and V-force 3 too, I aslo ride in diffrent alltitudes all the time, and with the pipes she's a bit sensitive on jetting.
Will ATACC solve my problems?
Is it reliable?
Thx
Rasmus (I'm swedish so my english may not be top class)
:winterrul
ATACC works great. You jet for the lowest elevation/coldest temp. Basically the richest jetting for what you ride. ATACC will automatically lean in out for the temp/elevation change.
Just remember if you add/remove mods that changes your baseline jetting, you need to change your jets. It will only lean from your baseline.
OK.
Do I need re-jetting for V-force 3 and Boost-bottle? Havn't installed them yet.
It's perfectly tuned now for the pipes and everythin'
Thx
you wont need to re-jet for the boost bottle, i dont think u need too for the reeds eitherbut im not sure on those. Do a search on boost bottles here. I have seen a few good right-ups on them on this forum.
yamaha_nisse said:
OK.
Thx
Nix, det behöver du inte.
No you dont have to rejet.
//Rob
go with the atacc. It made a huge difference on my 01 MM
Bender tripples made it crazy sensitive to altitude and temp changes.
Atacc fixed it. I have run it for 2 seasons without a single problem.
It made a big enough difference that without one I would change back to the stock exhaust.
