yamaha_nisse
Hi,
Havin' thoughts about instaling ATACC on my Mountain Max 700 '01.
I've installed Bender tripple pipes, and changed domes'.
Having plans to put Booost bottle and V-force 3 too, I aslo ride in diffrent alltitudes all the time, and with the pipes she's a bit sensitive on jetting.
Will ATACC solve my problems?
Is it reliable?
Thx
Rasmus (I'm swedish so my english may not be top class)
Is it reliable?
Thx
ATACC works great. You jet for the lowest elevation/coldest temp. Basically the richest jetting for what you ride. ATACC will automatically lean in out for the temp/elevation change.
Just remember if you add/remove mods that changes your baseline jetting, you need to change your jets. It will only lean from your baseline.
yamaha_nisse
OK.
Do I need re-jetting for V-force 3 and Boost-bottle? Havn't installed them yet.
It's perfectly tuned now for the pipes and everythin'
Thx
Thx
brandon_markie
you wont need to re-jet for the boost bottle, i dont think u need too for the reeds eitherbut im not sure on those. Do a search on boost bottles here. I have seen a few good right-ups on them on this forum.
yamaha_nisse said:OK.
Thx
Nix, det behöver du inte.
No you dont have to rejet.
//Rob
M-Max
go with the atacc. It made a huge difference on my 01 MM
Bender tripples made it crazy sensitive to altitude and temp changes.
Atacc fixed it. I have run it for 2 seasons without a single problem.
It made a big enough difference that without one I would change back to the stock exhaust.
