Does anyone know where I can find tunnel braces for the SRX??
I would like to get more grip for my feet as well as stiffen up the tunnel.
I have seen them before just cant seem to source any..
Roost 'Er
I run rox threads and you CANNOT slip there amazing, just harder to find
i looked and had no luck ...used is probaly best bet ...
OZ_872
I have the fett brorthers aluminum running board grips on my SRX and was thouroughly impressed by the fit and finish. just be careful not to drill through any heat exchangers. they have holes pre drilled but I added a few just because. The only bad part was they didn't have them in blue! So I got the natural aluminum finish. Can't remember where I got them, either Marshall or WPS. As far as running board supports i'm not sure on that one.
The rox ones I looked at, They look good I want to incorporate that into a brace for the tunnel.. Then drill out some holes where your feet go to get rid of some of the snow buildup.. Probably have to make it. If you guys come acrooss anything please post..
Going to be tough to drill enough holes/get them big enough to do anything with the heat exchangers running down the underside of the running boards isn't it?
dv8
I have the ROX on my viper. My second choice would by the Frett Bros alum finish footboards. For the price you can not beat them, plus its a clean polished look that works. I had the Yamaha tunnel braces and they are a waste of $ imo.
