hickey's got a yami
yea i know) i got the track hanging and the shaft is still in. do i take the set screws out of the pto side?? or do i take the spedo gear and stuff out too? and can i use 1.175 studs without taking the protecters out??
Check out the tec page information on track install.
valin
-Loosen off the set screws on the driveshaft bearing.
-Remove the 3 bolts holding on the speedo housing, pull off the housing, and remove the bearing from the driveshaft.
-Completely take apart the chaincase and remove the brake caliper.
-Either pull the chaincase as far from the bulkhead as you can, or remove it completely.
-Now you should be able to remove the shaft.
yes you can use up to 1.25" studs
valin
yup, I used to run 1.25" chisels on a .725" track
Utility knife?
That would be the easiest way to get it the rest of the way off.....but it really won't help you much with putting the new one on!
Madmatt
Madmatt
That's one way to do it. Reinstallation would be a bit tough. I wonder if you could sew it back together with some super fish line?? Make for easy track changes:-)
hickey's got a yami
thank you guys alot!! thats the rest of my project for this weekend. im kinda wondering what kind of sled ill have when im done. im puting a 1" track with 1.175 on clutch comes after track. i cant wait for snow or at least grass drags. thanks again guys!!!
hickey's got a yami
i just went on the tech page thanks guys
