Will the bearings and seals fit into the side arms that originally had the bushing setup? I looked at the parts fiche and the part number for a Viper with the bearings in the side arms is 8CX-47494-01-00, and the part number from my sled with the bushing setup is 8CR-47494-01-00. Just wondering if I could just buy the bearings/seals or if I'd need the actual arms too.If you have a Rx1/vmax xt/venture/rage/worrior, your sleds shocks and side arms do not have bearings in them. For the rage and worrior,buy the arms from below and remove the bearings and seals. You will need to ream out the side arm ends about 1mm to accept the bearings and seals. For all others you can just buy a used set from a viper/sx/srx/xtc and install them.
bbender785
going to bring this back from the dead, as it seems like an appropriate spot.
what do I need to be able to mount a normal, non-clevis style shock to the front of an SXR? is there a part from an Ohlins SX/SRX i need that will be a direct bolt-in, or need to fab something custom?
bbender785
looks like 8CV-2376J-00-00 and 8CV-2377J-00-00 from the SX. now to find them....is there a part from an Ohlins SX/SRX i need that will be a direct bolt-in?
