How much weight are you pulling in your srx?
98 MSRX with 00 srx 8dn-20 weights. I am running 4.5 grams in each hole, stock helix, 80 degree wrap...so...42 grams plus another 9 = about 51 grams.
As much as 57.7 - 8bu-00's with 4.5 in each hole - load it up til your RPM's start dropping off - SRX's like alot of weight - depends on the rest of you setup though
98' MSRX @ 3,500-5,000 ft., ...8DN-00 (stock), 2.4grams inner/outer empty, WYW primary spring, Ultimax 2 belt, 54/44 helix 70degrees, stock red, 2"/136 camo track, 8T drivers w/ 39/23 HYVO gearing (1.91). ;)!
I think I've got about 57 in mine right now. My sled does like a lot of weight, not sure if thats a good or bad thing.
