x2ryder New member Joined Aug 23, 2004 Messages 548 Age 49 Location Moline, Illinois Oct 11, 2004 #1 How much primary weight are you guys pulling in your srx's?
T Turk TY TECH ADVISER Joined May 2, 2003 Messages 2,806 Oct 11, 2004 #2 98 MSRX with 00 srx 8dn-20 weights. I am running 4.5 grams in each hole, stock helix, 80 degree wrap...so...42 grams plus another 9 = about 51 grams.
yammiman Member Joined Sep 28, 2004 Messages 662 Location Haslett, MI Oct 11, 2004 #3 As much as 57.7 - 8bu-00's with 4.5 in each hole - load it up til your RPM's start dropping off - SRX's like alot of weight - depends on the rest of you setup though
S srx_eh Guest Oct 11, 2004 #4 98' MSRX @ 3,500-5,000 ft., ...8DN-00 (stock), 2.4grams inner/outer empty, WYW primary spring, Ultimax 2 belt, 54/44 helix 70degrees, stock red, 2"/136 camo track, 8T drivers w/ 39/23 HYVO gearing (1.91).
x2ryder New member Joined Aug 23, 2004 Messages 548 Age 49 Location Moline, Illinois Oct 11, 2004 #5 I've got some new hauck adjustable weights and he has them set up for 60 grams
jwifferdill Life Member Joined Jun 27, 2003 Messages 399 Location Backus, MN Oct 11, 2004 #6 I think I've got about 57 in mine right now. My sled does like a lot of weight, not sure if thats a good or bad thing.
B bluehammer New member Joined Nov 5, 2003 Messages 322 Age 78 Location Northeast Ohio Oct 11, 2004 #7 68.7 in my Heavy Hitters
