Forgot to mention on my original post. The problem I have with the sled is that both the headlight and dash dim when the brake is applied.
Any ideas?
Smurf
Any ideas?
Smurf
yamyrider
did you add any electrical accessories or a brighter headlight....this is what happends when there is a bigger drain on the electrical system.
I had a 2000 SXr 700. I had tha same problem. If I remember right, I had a rubbed wire going back to the tail light.
braindead1684
Could also be part of the stator, my dads vmax did that and we found a burned out section the stator.
As mentioned above i would check for shorts and such first. If it doesn't show up anything then test the stator.
Nothing has been altered electrically. I will go thru the wiring to see if I can find anything damaged - good idea.
Any chance it could be the voltage regulator? Other than replacing it, is there any way to check it out? I seem to have 2 of them behind the guard on the right foot. That may be because of the electric start. Just trying to figure it out without going to a dealer.
Thanks,
Smurf
Thanks,
Smurf
check the wiring harness that runs under the motor
