I´m planning to buy a -95 Vmax4 800 ( longtrack version ).
What should I check for that sled before I go and buy it ? Is there any weak points to it or is it just gas up and go ?
Sled has not been driven for a last three seasons and it only has 1500 km`s on it. And that`s true ! ( I know the owner and the sled ) So it should be in near perfect condition.
I know that the price will be quite high.
Hope someone can help !!
Ike
I know that the price will be quite high.Hope someone can help !!
Ike
I would look over the track....somtimes the track will show if the guy cares about his machine....where and how he rides....just my 2 cents
bluehammer
I bought one new, ported and piped it and rode it for over 4000 miles. Great sled. I had the oil pump changed while under warrenty because the calibration was wrong and it gave me too much oil. Other than that it served me well. Go for it.
Re:
Bullet proof engine and drivetrain, I would go thru and replace all the fluids (don't forget the PTO drive) pull and inspect the carbs, drain the fuel tank etc.
srxguy
I had a 95 v-max 4 .....I love the looks of it...drive train was good, but it rode terrible......My buddy bought mine and I still like the looks of it, but he gets pissed when my srx kicks his butt.
chevy2
There must be something wrong with your buddys vmax 4 if a srx kicks its butt. I have a good running srx 700 and a 95 vmax 4 800 and there is no comparisson, after riding the vmax 4 and then riding the srx, the srx feels like a 500cc sled.
The v-max 4 has less horsepower and more weight than the SRX, doesn't it?
99yamahasrx
i used to have a vmax 600 i was wondering what kind of top speeds a stock vmax 4 800 would reach???
Thank you for all the info. It is much needed. Now I only have to decide about buying that thing.
I´m also considering -96 XT 600 or -97 XTC 600. My plan is to replace 121`rear with 136`or longer, if I buy either one of those 600cc sleds.
Decicions ...
Thanks again !
Ike
Decicions ...
Thanks again !
Ike
wildman
If you're looking for a good trail sled that is comfortable and reliable, I would go with the xtc hands down. With that said, there is no comparison in power between the 600's and the vmax 4. If power outweighs the ride quality for you, go with the vmax 4.
Re:
You are close,
the Vmax-4 800's had more HP and more weight than the SRX's.
ejcamaro said:The v-max 4 has less horsepower and more weight than the SRX, doesn't it?
You are close,
Re:
Not sure about the top speeds (how accurate is the OEM speedo @ 100 plus MPH) but I can tell you that at 120 mph I still have throttle to spare.
99yamahasrx said:i used to have a vmax 600 i was wondering what kind of top speeds a stock vmax 4 800 would reach???
Snowextreme831
I could feel a difference from a vmax800 and a sxr700. The sxr700 seamed faster. 800 ran good tho.
Im with the other guys....check all fluids. Change them all out. Clean the carbs and changed the plugs..cus then you just gave it a major tune-up! Also agrees with track..tells alot about the abuse..or non abuse the sled has been thru.
Look over the tunnel and look for any ripples...show its been jumped and tagged on the tail.....Take a quick look at slides and carbides...excessive wear might have caused damaged to skis or rails.
Just my 2 cents.
Just my 2 cents.
srxguy
....I had a 95 vmax4 and my srx....My srx would walk by my vmax4 at will...and there was nothing wrong with my vmax!chevy2 said:There must be something wrong with your buddys vmax 4 if a srx kicks its butt. I have a good running srx 700 and a 95 vmax 4 800 and there is no comparisson, after riding the vmax 4 and then riding the srx, the srx feels like a 500cc sled.
chevy2
You forgot to tell everyone about all the work you had to do on your srx, porting, v-force reeds, cold air kit, exhaust can, the list goes on...
Still wont smoke a vmax 800 with quad pipes 170+HP.
YAMMIEGOD3:16
SRXGUY, I ALSO LIVE IN N.Y. AND I LOVE TOO RUN YOUR SRX WITH EITHER OF MY V MAX 4 800,s !! I WOULD RUN YOUR PORTED / V FORCE REED SRX WITH MY 95 800 STOCKER ON GRASS. YOU GRASS RACE ? OR JUST SNOW AND ICE. 3:16 (tony)
srxguy
...................It was stock when i raced it....It now has quad pipes on it and its still not even close....not trying to argue....Just telling ya the truth.chevy2 said:You forgot to tell everyone about all the work you had to do on your srx, porting, v-force reeds, cold air kit, exhaust can, the list goes on...
srxguy
...................The srx was stock at the time.srxguy said:...................It was stock when i raced it....It now has quad pipes on it and its still not even close....not trying to argue....Just telling ya the truth.
srxguy
................ANY WEEKEND ON SACANDAGA LAKE...IN FRONT ON LANZI'S ON THE LAKE....SEE YA THERE!YAMMIEGOD3:16 said:SRXGUY, I ALSO LIVE IN N.Y. AND I LOVE TOO RUN YOUR SRX WITH EITHER OF MY V MAX 4 800,s !! I WOULD RUN YOUR PORTED / V FORCE REED SRX WITH MY 95 800 STOCKER ON GRASS. YOU GRASS RACE ? OR JUST SNOW AND ICE. 3:16 (tony)
