yours was plated like this what did you do punch a hole for tips to go through ? any other problems i am gonna have with this ?NYsledneck said:When i bought my srx the previous owner had welded re-enforcements in the w-arm. Well he too did not think of the tips of the rails going through the w-arm and it just caused more problems than before. You have to be careful on where you put any extra pcs and that it won`t effect how your suspension works.
The rails come through about a inch below the top bar.... All you would have to do is plasma cut the extra metal out there and you would be fine.. Or, i take it that your skids out.. just bolt it up with out the shock etc. in and push all the way down and you'll see where the rails etc. come inYA*AM*A*HEAD said:are the v cuts were the rail tips come through ?
ExpertXViper said:I can tell these guessets really werent planned out to well reason that being said.
The plates you have covering the whole W-arm arent not going to work. When the skid is fully compressed(bottom out) the front ski rail tips actually go through the W-arm right where the front W-arm mounting point is. Second was your plan to eliminate the rubber bottoming bumpers???? Cause the set up you have going now in now way are you gunna be able to install the stock bumpers and those are needed to prevent excessive bottoming/damage to W-arm
Sorry but from what Im seeing this gusseted W-arm will cause you more problems then prevent them.
