i put a 5 gallon bucket under each ski spindle and the back on the stand i have to keep track up and it is the perfect height to slip the rear suspension out ...plus you will need new bushings top and bottom of w arm most likely and make sure the shaft in the front mounts aint wore down at the ends ...look the w arm over real good ..and shim any play at bottom of w arm were bolts to the skid ...and mabe even drill and put grease zerts on bracket w arm mounts to on the alunium rail .also the shock bushings are probaly sloppy you might have to loosen it a bit to see instead of using the nylon bushing there is a actual roller bearing that can be incerted instead of plastic and seals to keep clean just depends on what kind of time and money you want to put into it ...cost about 120 for all new bushings and cross shaft ,and bearings and seals to do rear skid ...my skid has 2100 miles and its trash am getting a new skid ...i am in the process now here are all the parts you need to add bearings, seals, and the bushings and shaft for the w arm parts are for a srx not sure if different for sxr
Qty Part Number Description Price Total
8CR-47465-00-00 SHAFT 1 $29.73 $29.73
90381-19111-00 BUSH,SOLID $3.63 $7.26
90387-1009T-00 COLLAR $2.89 $5.77
90381-15112-00 BUSH,SOLID $2.31 $9.25
93315-21454-00 BEARING,CYLINDRICA $9.79 $19.59
93109-14021-00 OIL SEAL,SDO-TYPE $4.56 $18.24
90202-14226-00 WASHER,PLATE $2.66 $10.64
90387-1007N-00 COLLAR $6.05 $12.11
SubTotal $112.58
