I bought a unused set of power inc triple pipes for my 98xtc700 from a vendor at the epping grass drags.They were missing the set up instructions,mag spring bracket,and springs.The part #on box is paw-2383 97-99sx race pipes.The pipes i have look like the ones on the tech page but the instructions on the tech page say for paw-3028.Can i use the jetting/clutch setup on the tech page or is there a different setup for these pipes. Thanks for any info chris
grapeape
Are they center dump or end dump (expansion chambers)
Turk
TY TECH ADVISER
- May 2, 2003
Those are awesome pipes. Run 47.5 pilots, 147.5 mains & raise needles 1/2 right across. Run premium fuel & clutch the sled to run at 84-8500 rpm.
Grape ape i believe they are end dumps. The chambers end about 4" from the end of the header tube.The guy wanted $400 and i got them for $350 so i figured i got a good deal on them.grapeape said:Are they center dump or end dump (expansion chambers)
Thanks turk. Would my 8ca's and 50/42 helix work for a clutch set up?
