Hey guys i was puting on my new carbides and I stripped the second bolt from the front of the ski on Both SKIS. I have all the other three bolts secured.
I am sure this has happened to some of you, my question is will it be ok If I do not secure that bolt or should I just buy new carbides and try it again
THanks
THanks
Cut off the stripped threads. Take a new bolt and cut the hex head off and weld it in place.
stein700sx said:Cut off the stripped threads. Take a new bolt and cut the hex head off and weld it in place.
Yep X2!
NY AttakGT
Or just rethread the stripped bolt on the carbide and get the correct sized nut to go on the new threads.
I wouldn't recommend just leaving it as it is....definitely take your pick from mine one of the suggestions above.
--Steve (O.C.)
--Steve (O.C.)
PZ 1
- Mar 12, 2005
If the stud is long enough- put another nut on top of the stripped one, or if the stripped nut is off, put a spacer or some washers on the stud so a good nut will seat on the good threads. And don't tighten it so tight!!
If the carbide bolt is stripped on the first two or three threads just cut them off and try to put the old bolt back on, if the old bolt is not stripped.
