bleeding the oil pump on a 04 viper mtn?
Vector88
Labrador, CANADA
can anyone help me. i want to make sure i have this done right so can someone tell me how to bleed my oil pump. i had my motor out of my viper now i want to make sure my oil pump is bleed before i start using her next month. step by step would be great if someone can do this for me.
its very simple, just simply remove the little 8mm headed screw next to the center cylinder reedcage, youll see the bleeder tube bolted to the reed block, remove the plug and the oil will start to come out and bubble, replace the bolt and thats it, super simple.
