SRX7
as I said before it won't make no big deal power wise change it if you want its your money.
Oh by the way welcome to the world of sledding. $$$$$$$$
Corey9965
How much would a dealer charge for new valves, cables and servo? ANyone know? Just curious.
Corey9965 said:How much would a dealer charge for new valves, cables and servo? ANyone know? Just curious.
Your prices are differentin the USA, we get hosed up here, a cable is around $56 plus taxes and a power valve is around $126 plus taxes. I don't even want to know what a servo motor would cost.
Yamahasrx700
There is a HUGE power difference if the cable is pulled through and the valve does not open.
SRX7 is talking about the nic in the PV not a cable pull through.Yamahasrx700 said:There is a HUGE power difference if the cable is pulled through and the valve does not open.
SRX7
Thanks D
Yamahasrx700
10-4 that makes sense
If you go to teamalpine.com a yamaha dealer here in USA, the valve is 109 each, and a cable will run you 23 $$ I think. Thats the best deal I have found on NEW Yamaha parts. Usually the servo motor is ok. You can find better deals on used parts.... I would buy New cables though.
Mine was almost pulled through and was really tricky to get the cable out due to the way it was worn in the slot. I ended up drilling out and replacing the end with a piece of stainless steel. I found the info on the forums here. Very easy and worked great.
