cadmo
what has to be done to swap to bigger carbs on my 04 viper with dcs?
the carbs wont interefere with the dcs(detonation control system) but youll need to do something with the tps(throttle posistion sensor) located on the carb rack if this is a trail sled. You can get a block from an aftermarket company in which your tps bolts up to it and it tricks the cdi box into thinking its still hooked up. In drag only cases I just simply plug them in and leave them at rest, it doesnt effect wide open hp one bit, its only for mid range cruising it adjust the timing a little bit, but no change at wot.
