iowasrx
Hey guys, just got the 01 SRX out of storage and started it this last weekend. Noticed the temperature light flashes 3 times. If I shut it off and restarted sled, will flash or may not. Any ideas??
flash if it overheat
iowasrx
It was right after the initial start-up. Wasn't even warmed up yet.modsrx said:flash if it overheat
Yamidude59
that light is supposed to blink right when it starts up. not sure how many times though, but it blinks.
iowasrx
It kept blinking. Flashed 3 times, than quit for a bit, than 3 more times and so on. Wouldn't stop as long as it was running.Yamidude59 said:that light is supposed to blink right when it starts up. not sure how many times though, but it blinks.
Yamidude59
There are specific codes for each flash sequence, do a search on it (up in the tool bar "search") Type in Diagnostic codes, if that helps
iowasrx
Searched here in the technical section. From what I can tell it is telling me "discontinuity of the variable resistor (thumb warmer) is detected. What do you guys think? Hard fault part or wiring?Yamidude59 said:There are specific codes for each flash sequence, do a search on it (up in the tool bar "search") Type in Diagnostic codes, if that helps
mulderdad
From what i remember, (not much LOL )
The 3 flashes is the pvs cycling through a diagnostic at start up. I always looked for the 3 flashes at start up and knew my pv's were good to go. This is normal.
If I understand you correctly, at start up it would flash 3 times then a pause, three flashes and then a pause, 3 flashes etc?
The first thing I would do is pull out your wiring harness under the motor and check for rubthroughs. The srx is FAMOUS for it! My srx was rubbed through in like 6 spots when I first got her.
I am sure you'll get some experts to chime in on this.
Cheers,
Rick.
Cheers,
Rick.
mulderdad
Also check above the left footwell I had two rub throughs there also behind the vent. It was arcing out right above my left foot. Only noticed it b/c it was doing one time at night.
So it's 3 qwick flashes,pause then 3 qwick flashes???
mulderdad
mulderdad said:If I understand you correctly, at start up it would flash 3 times then a pause, three flashes and then a pause, 3 flashes etc
Is there and echo in here? Sounds pretty similar to my post there daman.lol
What did you find out iowasrx?
Have you pulled your wire yet and your pv's??
mulderdad
Your wiring harness under the engine!
iowasrx
Yes, and it repeatedly does this. Now if I shut it off and start it back up, it may not flash again til the next time I start it up.daman said:So it's 3 qwick flashes,pause then 3 qwick flashes???
iowasrx
I have not checked yet. I'm hoping to tonight. I will let you know in the morning!mulderdad said:Is there and echo in here? Sounds pretty similar to my post there daman.lol
