Drag & Fly Clutch kit?????
sledneckdon
Upstate, NY
What is the best clutch set up fro a 2004 Viper S stock with no studs?? Heel Clickers or the Drag and Fly. I am looking for midrange and TOP end increase!!!
If the Drag and Fly kit is recommended what weights and spring combo should I use or does it come with the Kit from Supertorquer???????
ive set up many vipers with a pin kit from straight line perf to use cat weights better shift curve takes a bit to get set up but worth it
Dragon-flys
I Bought one for my 02 viper, works good but i havnt had a chance to do any testing with differnt setups. kit came set up for bender pipes. could be better on low end, beats a yamaha apex in a drag race. I pull him in the midrange.
sounds good, but I don't have pipes on mine. I would like to achieve more on Midrange and Top End. My dealer gave me his set up last winter and I lost 10 MPH Top end so I want to get that back at least and then some if I can do it with the drag and fly or the orriginal Heel Clickers not sure what would be better.
Would you share that set up with us? My guess is too little tip weight?
Or to steep helix.. end angle
reinforced w arm pic
could somebody be so kind to post of pic of a reinforced w arm.i read betheviper thread on proaction fix but could really use some pics.thanks
Heelclicker 40-10, 4g heel, 3g tip, red spring from kit, advatage 48-40 helix or even shallower finish angle. I did 95 mph stock on my 02 did 103mph on a bumpy lake with the 48-40. Still pull over 100mph with my 136"
