PZ 1
- Mar 12, 2005
There has been ethanol in fuels in Wisconsin and other states for many years and many people have been using it without knowing it and without problems. It was first available here about 1980. Ever since it was first used there have been people wringing their hands and running around saying that the sky is falling.
There have been warnings about how the alcohol will draw large amounts of water from the air. A service instructor said that the alcohol will absorb moisture until there is phase separation of the water and fuel and then continue to absorb it -as if when you have gas containing alcohol in your tank, that eventually water would come pouring out the filler hole.
The alcohol does not cause carb icing problems. It is caused by moisture in the air. It will not cause fuel system freeze up. On the contrary, what is added to gas to prevent that? Fuel de-icer, also known as alcohol.
It has been blended with gas by refiners for many years to raise the octane level of gasoline. E-85 has a 110 octane rating (as an example- not to be used in sleds).
The alcohol will cause slightly leaner running, which in most cases is not a problem. As stated here, it can be compensated for with a jet change.
When a piston and cylinder is scored, some now automatically blame the alcohol blended fuels, while there have been a bazillion pistons and cylinders scored on straight gas.
