So does anybody know why so many red head engines crack around the pull start? Has there been discussion about this? It is obviously a very common problem.
pops said:yes i would also like to know i have been hearing more and more guys having this problem should i replace my crank bearing now while my redhead is running strong
I agree 100%. I would have the update done also.stein700sx said:I would change the mag side bearing, even if it is running strong. Mine went out with no warning. Sure sucks replacing pistons,jugs and heads and having crank work done.
Yamaha fixed the mag side bearing issue in 98Nicko said:I have a 99 sx 600, and it looks good with 5000 miles, but I will maybe work on it next summer....Did the 99's have this issue also...?
Nick
Blkhwkbob said:The 97 sx had a problem with a lack of oil getting to the mag side bearing.
By the way how is that crank and case I sent you.....? Looks like brand new doesn't ?
Nick
