viper suspension in srx???
j2hizzo
southern maine
just purchased a viper suspension out of a 02 viper 500, and want to know if there is any mods that i have to do to make it fit my 1998 srx 700? I also will be putting in a inch and a quarter ripsaw track, I know I either have to cut the track or remove the coolant guards, I would like to do the removal of the guards. Anyone with ideas??????????
they are the same skid except viper is long travel ...you could just swap the shocks and limiter straps and make yours long travel ...instead of swapping the skid ...remove the front heat exchanger protectors if you are not gonna run studs or cut down track if you are running studs ....if you do swap the skid and part out old skid i need a set of rails ..let me know if you plan on parting out or selling as whole ..
