Iceclimber
Hello!
Anyone know if there is alot to modify to get SLP trippelpipes to fit in a Viper Mtn with revers? (Dont have electrical starter)
/Jimmy
/Jimmy
All I had to do to install on an 05 was trim 1 tab (I think it is for the batery tray to sit on?) on the chain case cover to clear the can. There was some pictures on here when I was looking last year. It was a tight fit but worked fine. Be sure to use lots of heat tape where it is close to the plastic.
Iceclimber
Ok. Sounds good.
thanx for fast answer.
dirtjumper895
I am running the speedwerx triiples with race cans on mine... I trimmed both battery tabs, and had to relocate my battery. I am moving it to the trunk.... Not too sure if you will have to do all of this, but thought i'd give my 2cents..... BTW x2 on putting lots of heat tape...
