Boost Bottle with vforce
JohnnyQuest
Minnesota
Will the center carb clear the steering column if you use the boost bottle with vforce reeds???
Because I know that if you have reed spacers and the bottle the center carb bowl will rub if you do not modify at all!
Boost Bottle
Hey Johnny- No help here, but when you get it dialed in let me know how it works. Want to do it to my MM. :letitsnow
On my sled with the stock reeds, I had to put the pads under the air box to keep the steering shaft from rubbing. A simple fix and nothing to worry about after that.
Thanks Guys!
I have ran the bottle with the stock reeds and spacers with the airbox shimmed in the past. I just wanted to know if I needed the shim the box on the sled with the vforce too. As I have 2 sleds now.
According to yammyrider everything will fit no problem. I'll just have to fabricated a bracket to relocate my coils and machine some carb boot adapter rings to accomodate the different size (Straight) carb boots that you use with the snorkel tubes!
Any other comments or concerns that I should look for off the top of anybodys head??
