procharged04
Does any buddy no how much play should the brake rotor have should it move back and fourth on the shaft? Put a new track on and cant figure why i dont have any brake response. Did i put something back together wrong? I had the disc and caliper off when i put the new track on. Also the pads dont touch the disc when brake lever is pulled.
Yamidude59
it should move a little on the shaft(secondary moves in and out a little to compensate for alignment), but you probably have to adjust the brakes.
procharged04
i have almost adusted the brake all the way out
braindead1684
Did you put the key back on the shaft before putting the disk on? Does the disk turn on the shaft?
I'm with ^^^ I think you missed the key.
edunn69 said:Did you put the key back on the shaft before putting the disk on? Does the disk turn on the shaft?
I agree or it's possible that #15 fell out.
procharged04
Does anybody have a number 15 that they would beable to part with. I took it back apart @ that is missing. I cant find it either.
procharged04 said:Does anybody have a number 15 that they would beable to part with. I took it back apart @ that is missing. I cant find it either.
Kerby I will throw one in the box with your silencer.
