Put a new track on my SRX this weekend and I'm feeling like I have a problem.
As I put the shaft back in and slide the chain case back on, It's looking as though the chaft is not sliding into the chain case enough. After I place the sleeve onto the shaft, I only have about 1/2" of shaft remaining to set the gear on. Less than half of the gear is on the shaft. When i look under the tunnel, it looks like the shaft should shift 1/4 more towards the chain case side. But, it won't budge. When I look at the speedo side the bearing sticks out about 1/4". I this right or should it be flush? I thought that by tightening the case down it would suck the shaft through more, but not much and I could hear a slight pop on the speedo side indicating pressure on the speedo housing. Not sure what is happening.
I lost track of which sleeve went wear on the chaft. On the inside of the chaincase(tunnel side), I placed the smaller sleeve then the oil seel(sleeve). feed through the case than add the slightly larger sleeve, then the gear. Is this correct?
I hope this is not too confusing.
