99SRX600RRR
What is the best way to fix a hole in one of the pipes? It is difficult to see, but it looks like one of the spring bracket tabs pulled away from the pipe.
What is the best way to have this fixed?
Thanks!
Thanks!
Weld it on up man. Do you have access to a MIG welder? If you do, or know anyone, Just tack it up.
hereismylife
I agree just tack weld it or have someone weld it for you.
patsxr700
welcome to the world of welding lol
99SRX600RRR
I kinda figured welding, but I have heard thoughts of brazing... wanted to know what the Yamaha community on here thought.
Thanks guys!
Thanks guys!
last time i fixed a set of tripples i actually cut a thin patch like a 3" by 3" tack the corners and use a torch to bend it around the pipe then weld around it, if you just try to weld the hole your going to risk having pieces of wire and shit in your muffler, get someone to tig weld it up if available, take the info from a welder himself :-)
tedgoesfast
ive welded patches on but make sure no pieces of pipe hanging down which can affect flow
RIVERRUNNER
Yep take your time, clean it up and weld it......^^^Like they said keep the chit out of there at all costs!!!
