yamahaboy701
Yamahammer485 said:Lookin good dude!
Going to keep an eye out for your sleds + trailer!!
For your can, you should wrap it with header wrap. Keeping it hot makes you gain power that you would typically loose with adding a can with the end result maybe slightly more power than stock. Header wrap is $30
I will look in to this. I have access to a dyno so I might do a test to see what the heat fade would be wrapped vs un-wrapped. One of the perks of being the head of the snowmobile team on campus.
