Concept Carbon
Im thinking of makeing a set of aluminum or carbon fiber upper and lower control rods. Just wondering if i can do with out the bushings and use ball ends on both ends of the rods would make it alot easyer to make and also replace.
Are you talking about the front suspension radius rods? My mpi ones have heim joints on each end. Works great.
Concept Carbon
yep same thing. thanks
if you want to make something really light, use rubber bushings in both ends, heim joints are heavy.
Concept Carbon
good idea I wasnt aware that i could do that. I thought that it needed a ball end in case it wasnt a even load( hard to explain)
Danger Dog
Use aluminum heim joints on both ends they are lighter. Unlike most that you get they use the stock inner ends. If the price is right I would be interested.
1995vmax500le
hey i would also be interested. just curious are u going to make the ski stance wider as well cus i am lookin into widening the front of my viper 2 or 3 inches overall. im a machinist and have access to the epuipment and materials but unsure of geometry and stuff like that.
