Taphee said:
Okay I broke down and called Port Yamaha. What a bunch of great people. I explained the situation of the track sitting on the top of the shock as pictured. This is completly normal. I didnt believe it until John explained why and makes sense. The track stays tight on the top so when you let off at full throttle it does not go flapping into the tunnel.
I don't know what the guy above is talking about, the track stays tight all around, on every wheel the same and its not so when you let off the throttle. I think an i dont know would have been a more accurate statement form him.
they run close to start with yes, touch, no. There are two things going on here, maybe three, and four.
1 bushings in upper arm are wore allowing the shaft to set lower in the sissor arm tube.
2 shaft is worn(usually sx/viper/rx are aluminum) allowing the shaft to set lower in the sissor tube.
3 the wheels are worn a little allowing the track to set closer to the sissor arm
4 when the track is tightened over two wheels at the outter ends, it wants to bow down where there is no wheels.
If a couple of these things are going on let alone all of them, you will have trouble.
Not huge trouble but it will wear a line in the track, sometimes bad gouges over time.
It will look worse when you sit on it and may not be noticable when you lift the sled in the air if it is the bushings or shaft.
I fall back to my standard comment that is, even if your skid has low miles you should tear it down and tighten it up.
