M-10 Hyfax?
n8sjh
Grand Rapids Michigan and Kalkaska Michigan
I have a 1994 v-max 600 that has a m-10 under the rear. I pulled out the suspension to replace the hyfax. Anyone know what kinda hyfax I have to look for as far as brand? Skidoo yamaha artic cat polaris?
I ran up to my local shop and it was closed? Thanks
i have an m-10 and i bought mine from a polaris dealer. the guy looked real disgusted and not very nice when he asked what machine it was for and i said yamaha! lol... with an m-10... lol....also, you can call fast and order them over the phone or website!
if you want the exact ones, they come from a 96 formula III or mach1. they are hard to find in stock anywhere. I took a grinding disk and ground down the sides of each rail about 1/32 on each side, then chamfered everything with a file and smoothed the edges off. This will make a stock yamaha slide fit right on.
M10 Hyfax
I bought a used standard m10 (2001 or newer with new style slider block system) that I am reconditioning for my Viper. I slid some old hyfax from my old '96 VMAX-XT and they slid on, but were loose side-to-side.
BTV - which M10 do you have, and when you say stock Yammi hayfax fits, are you talking about the stock Viper P-Action hyfax? These may be different than my old VAMX slides.
I am hoping I can use the newer Yammi slides since I have a new set up at the lake.
Thx !!!
FYI - Make sure the Hyfax is a tall-enough profile, and watch the rear shock bottom eyelet clearance to the track. I just bought a used M10, and when I removed the rear shock during the skid overhaul, this is what I found. I called FAST and sent pics to them, and they said the damage was from using the wrong Hyfax. Will cost me $45 for the bottom cap, and the cost to replace oil and recharge the shock. About $100 in damage to save a little on hyfax....not a good deal IMHO.
I bought the correct Hyfax from a Polaris dealer. It is really thick, and is for the Edge chassis w/M10. The dealer knew exactly what I needed as soon as I said "M10". Not cheap though, $19.99 / side. You know its correct because the surface of the installed hyfax is level with the rear wheels at the back. I will post a pic showing what I mean a little later tonite.
Ride safe, and keep the rubber side down !!!
