n8sjh
I have a 1994 v-max 600 that has a m-10 under the rear.  I pulled out the suspension to replace the hyfax.  Anyone know what kinda hyfax I have to look for as far as brand?  Skidoo yamaha artic cat polaris?
I ran up to my local shop and it was closed? Thanks
I believe any Poo dealer has them
			SWEDE
The older metric versions  of the m-10 are ski-doo I believe, but I'm not sure which profile.
			sleddheadd
i have an m-10 and i bought mine from a polaris dealer. the guy looked real disgusted and not very nice when he asked what machine it was for and i said yamaha! lol... with an m-10... lol....also, you can call fast and order them over the phone or website!
			grapeape
if the sled has metric bolts, get the ski-doo hyfax, if it has sae bolts, get the polaris hyfax
			n8sjh
Ok thanks guys.  I think it is going to be a doo
			yamachuck
my m 10 used a yamaha hyfax 2001 and newer m 10. slid on well had to drill holes bigger in hyfax .no problem
			JJsRX1
Team Fast
This will get you to team fast and they will be able to tell you what you need.The web address is www.teamfast.com
							T.S.U.Filmz
If it is a do slide it is profile 8
			if you want the exact ones, they come from a 96 formula III or mach1.  they are hard to find in stock anywhere.  I took a grinding disk and ground down the sides of each rail about 1/32 on each side, then chamfered everything with a file and smoothed the edges off.  This will make a stock yamaha slide fit right on.
			n8sjh
Thanks guys.  I found some at a small local shop in stock.
			mdbauer62
M10 Hyfax
I bought a used standard m10 (2001 or newer with new style slider block system) that I am reconditioning for my Viper. I slid some old hyfax from my old '96 VMAX-XT and they slid on, but were loose side-to-side.
BTV - which M10 do you have, and when you say stock Yammi hayfax fits, are you talking about the stock Viper P-Action hyfax? These may be different than my old VAMX slides.
I am hoping I can use the newer Yammi slides since I have a new set up at the lake.
Thx !!!
Thx !!!
n8sjh
I went to a local shop and it was ski-doo hyfax.  I just took off the old what was left and matched it as good and I could.
I have a early version that is metric.
I think the American version is polaris.
mdbauer62
FYI - Make sure the Hyfax is a tall-enough profile, and watch the rear shock bottom eyelet clearance to the track. I just bought a used M10, and when I removed the rear shock during the skid overhaul, this is what I found. I called FAST and sent pics to them, and they said the damage was from using the wrong Hyfax. Will cost me $45 for the bottom cap, and the cost to replace oil and recharge the shock. About $100 in damage to save a little on hyfax....not a good deal IMHO.
I bought the correct Hyfax from a Polaris dealer. It is really thick, and is for the Edge chassis w/M10. The dealer knew exactly what I needed as soon as I said "M10". Not cheap though, $19.99 / side. You know its correct because the surface of the installed hyfax is level with the rear wheels at the back. I will post a pic showing what I mean a little later tonite.
Ride safe, and keep the rubber side down !!!
