Clutch and jetting
00sxrjoe
Maine
I have a 00 sxr 600 with snowstuff can boyson reeds and a boost bottle drilled air box stock clutch and gears. Last winter it went all year with no plug changes. 1000 miles this year i have done all the add ons but can. Do I need to clutch it or jet it now.
:2strokes:
if you have the airbox drilled, i would be fattening up the mains for sure. depending on how "swiss cheesed" the airbox is now, would determine how much you need to fatten it up. you could find a more aggressive clutch setup for your sled. you can check the tech pages, as turk should have some setups posted for your sled in their. also, in the tech pages there is a chart, where all sorts of riders posted their setups. you could check that chart out as well.
