patsxr700
I just took out my 2002 srx 700 that i just bought, it keeps on fouling the middle plug.. it just runs on 2... i sure hope i didnt blow it up!! i cleaned the carbs and everything.. first ride of the year and it doesthat to me... now every one thinks its a slow sled and its junk.......
take a breath........pull the plug check the cyl(comp test),got fresh premium gas in her?
when does it foul at start up or riding??????
mopar1rules
was there any preventative maintainance done to it at the beginning of the year? like carb cleaning, power valve cleaning, new plugs, etc? i had problems w/my '99 srx 700 fouling plugs on the pto cylinder and it turned out to be a bad spark plug cap. does your plug cap, kinda just set on the plug, or does it have some resistance and then "click" on? is the plug all full of that black sooty dust on the outside, underneath where the plug cap is? if your carbs weren't cleaned, maybe you have enough belt dust, covering the air jets. this would make it run a little richer. also, if the carbs came off for cleaning, maybe the choke cable was missadjusted and the choke is on a little? what plugs are you using and what's the gap? what is the condition of the reed petals?
patsxr700
well first i had it running great at the shop.. it was retarded fast then i go to the park with my buddy we unload them and i let my let warm up then i fouled the plug i put a new plug in it which was br9ecs then it just foul.. i didnt even take off i am using 98 in it and it fouled the plug was just wet... then i had to bypass that stupid sen. it wouldnt let my sled go over 3 grand..
Yamidude59
That stupid sensor saved your motor from blowing up.
patsxr700
yeah how?? lol
patsxr700
the sensor is for the throttle from sticking lol
Yamidude59
its the TORS, if something isn't right, your motor will run away, so therefore it redlines your sled at 3 grand.
Yamidude59 said:its the TORS, if something isn't right, your motor will run away, so therefore it redlines your sled at 3 grand.
Mine has been bypassed for the past 6 years of owning my sled. It was bypassed by Iantomasi.
Yamidude59
Clean your carbs and Make sure your plug boot isn't all corroded, pull cap off (screw it off) and check the wires and see if they are corroded... may have to cut some wire off to expose new wire (don't cut alot, don't do that until your carbs are cleaned and the plug cap isn't all rusty inside) then see how it runs then do that if it is corroded.
good luck
good luck
Yamidude59
98700 said:Mine has been bypassed for the past 6 years of owning my sled. It was bypassed by Iantomasi.
I still like having that feature... Your motor is modded, and if you had it on it would probably be activated all the time... As for my stocker... its nice knowing there is a sensor for it, never came on though, and good thing too.
patsxr700
yeah its quit easy to bypassed i cleaned my carb i will have to check my plug caps
Yamidude59
Pat, you had to bypass it because your motor would not rev up correct? its telling you somethings wrong, why bypass it and risk something bad? heck it could just be activating from a tight throttle cable...
Just lookin out for ya, not bashing man
The TORS system relies completely on two mechanical switches. One in the flipper and one at the carbs. The only real reason to disable it is to rule it out as a problem. The most common reason? Too cheap to buy a new switch. With proper throttle cable adjustment, the system will work as intended regardless of mods. Anyone that has disabled the system should be at least running a tether, so that when you get thrown from your sled during that 'watch this' moment, the sled doesn't take off due to a frozen throttle. [/soapbox]
patsxr700
its just 2 wires the sensor is for the throttle from sticking lol see if it sticks it tells the motor to stop at 3 grand so it doesnt go flying on you..
Yamidude59
let us know how it goes... Hopefully its just the plug cap being loose or corroded...
patsxr700
yeah i will work on it tommrrow after work...
blueblooded
Also,all my srx's did not like alot of choke.I fouled a few plugs until i figured it out.This is how all of mine were....cold engine....full choke...as soon as it fired up...went to half choke...10 seconds at half choke...turn choke off and let it warm up a few minutes.To restart when the engine is hot lightly give it a liitle gas and pull....fires everytime.After i figured out what the sled liked,i never fouled another plug.
Also make sure it's good and warm before trying to ride off, lift the hood and feel the head if you have to.
Triple X
blueblooded is right on the money, SRX's came with a very rich choke. If you follow his directions you shouldn't have any more fouled plugs at start up.
