According to my shop manual I'm supposed to have a certain amount of belt above or just below the secondary for proper deflection.Now my sleds problem is that with the new 8DN belt its very tight.I've taken all the shims out of the secondary bolts which decrease or increase the gap and this still does nothing.The belt loads up the motor when on the ground as its grabbing the primary shaft.also I noticed that the belt favours the engine side of the sheave on the primary.Is it supposed to be centered on the primary with proper alignement,(offset)?I know there is the center to center which might be at the greater setting causing this excessive tension.Any answers on the eqaul distance between the belt sides on the primary?
