Suspension Lift Kit ???
jholden
Byron, MN
I did some searching and didn't find much. I have an '02 Viper that is bone stock. I am 6'4" and 290lbs. I am interested in lifting the suspension or ride height of this machine. The shocks on my viper have not been revalved at all. I am comfortable with the amount of suspension movement, but would like a higher baseline. Looking for ideas to create about 3 inches in the front and rear. My thoughts are to increase the spindle length on the skis and add a bushing under the trailing arms for the front and fab a new bracket for the rear mount on the skid. Why: Because I am fat and when I get on the moguls, it seems like a snowplow through some of them. Any help would be appreciated.
if you look at the last bolt that holds rear suspension in place the one closes the tail end there is a plate rivited to inside of tunnel you can switch that one for a plate off an earlier V-max mountain max that will give you about 3 to 4 inchs in back
Check on eBay, there is a guy selling lift kits for sleds. I bought a set for the front of me srx and it gave about 1.5 inches as a shock mount replacement.
I decided to buy a new set of rear mount plates from CBPerformance that will give me an extra 2.5" or 3.5" in the rear. I installed a new Cobra 1.352" track in my sled and was going to remount the suspension at that time, but decided to wait until later as we got snow and I wanted to get riding. The plates look very nice from CBPerfromance.
