braindead1684
Was checking the sled (96 vmax XT) over before trying to start it and when I watched the oil pump when playing with the throttle i noticed it pulls open fine when opening the throttle and returns about 1/2 - 2/3 then slows as it closes the rest of the way which it does fine. Not sure if this is normal or maybe the lines are a little froze up until I run it a while and brake them free. Unfortunetly i couldn't start the sled after about 30-50 pulls (appears theirs some water in the system thats froze i assume or something in the carbs i don't see any gas showing in the lines as I pulled it over(with ignition off).
