Tunnel protectors = track rubbing...
Spaz's SRX
Northern, IL.
I just finished up installing heat exchanger and tunnel protectors on my 98 SRX. I also installed 144 studs into a fairly new 1" lug track. While I was adjusting the track it seemed offly hard to rotate by hand, noticed the first front foot or so of the track rubs on th protectors, should i be worried? If it makes a difference, the tunnel protectors I ordered are from Yamaha.
must be your aftermarket track isnt notched on top of the track clip windows, your lug must go all the way across it. you can either let it wear in(rub), or notch it with a razor knife on top of the clip a bit.
Is this a common problem? I still need to install the front heat exchanger protectors, do you forsee any problems with this? Thanks for the response.
It will scrub off some speed for about 200 miles, then it will be good to go. Itis only a problem with unnotched tracks. Maxdlx
I had to remove the complete track assy to install the heat exchanger protector on wifes sx. My sx already had protectors installed, the track rubbed the protectors for heat exchanger until I ran for awhile. track was about 1.5 inch away from tunnel protector.
sounds stupid but how do u know if its notch or not... i'm in process to install protector
hey
I have a ultramax track and it rubs up front... ripped a few chunks out...but never really bothered me till I read this post and it reminded me about it again...I have about 2500 km's on this track so it's still there anyways...lol
this year I am running an Actic Cat Camoplast track in reverse. You can pick these up on ebay new for around $200. Oh 1 inch lug
Look at the lugs where your track clips/windows are, if that area is the same hieght as the rest of the lug, its not clipped.
Just clip it, will take at most 30mins and a good pair of side cutters or a sharp knife then no rubbing at all.
Like sno-xr said right on top of the windows
