Pod and light upgrade on a 99 srx
Styles211
Woodstock,Ontario,Canada
Could someone fill me in on what I would have to do to upgrade my 99 srx to a double light like the 2000's. Also, will I be able to do this with out buying a new hood.
Thanks!
stator ,guage pod,light,windsheild, reuse you hood ....i belive thats all you need to do it ....
they will bolts at same place but the crank trigger will not fit cause the flywheel is smaller u will need to do some welding to install the new crank trigger... u will need stator ,flywheel,harness,cdi ,relay ect
