question on low oil light flickering
Rambunctious
Holland, Michigan
oil light flickers, even when full
pump is fine and all that
question. if I buy a take off oil reservoir, am i all set. or is there a common problem with a wire shorting soemewhere else
thanks
Ramb
what sled??
Danger Dog is right 9 times outa 10 it's the sending unit,replace that and
you should be good to go..
oil level indicater
I had the same issue, needed it for a 600 sxr and bought a viper tank that had the sending unit in it and that solved the problem. You can confirm fit by checking on yamaha parts web site for part numbers.
