Rambunctious
oil light flickers, even when full
pump is fine and all that
question. if I buy a take off oil reservoir, am i all set. or is there a common problem with a wire shorting soemewhere else
thanks
Ramb
thanks
Ramb
Danger Dog
Sounds like the sending unit in the tank. Had on do that a few years back.
what sled??
Danger Dog is right 9 times outa 10 it's the sending unit,replace that and
you should be good to go..
I've had one go bad as well(sending unit). It was doing the same as you describe. 2000 Vmax 600 DLX
rlbock
oil level indicater
I had the same issue, needed it for a 600 sxr and bought a viper tank that had the sending unit in it and that solved the problem. You can confirm fit by checking on yamaha parts web site for part numbers.
YAMMIEGOD3:16
MY 2000 SRX HAD SAME PROBLEM. THIS WAS WARRANTIE FIX RIGHT FROM YAMAHA. NEED PART # ? 3:16 (yammie tony)
Rambunctious
2000 srx
thanks. seems they are going for about $10 in use parts
thanks
Ramb
thanks
Ramb
