mopar..I don't remember.Got them off e-bay last season.I'll try to dig up the make.
mopar, double check the spring tension at the mounting point(where the slot head hits the carb screw. i remember when i first put these on i had one hang up. should be slight pressure to compress the spring. i bench mounted these and trouble shot them prior to sled install.i hated them at first, but once dialed, they do work. you could always contact bender, but i think all the old school boys are gone. if you think i sold you junk, i will gladly put them back into stock.
